Server Version#: 1.32.5.7349
Player Version#: WebOS Latest
In the last few weeks, I’ve been getting transcoder crashes while streaming locally. I’ve updated drivers, I’ve downgraded Plex. I’ve checked storage etc.
I honestly am out of ideas.
I’ve had several in the last hour (current time is 8:45PM Central 8/1/2023)
Could someone take a look at the logs and see if they can find any reason for this?
The QA AV1 machine (RocketLake + Nvidia RTX 3060) has the 525 drivers installed.
My personal machine has the working 535 drivers with a P2200 .
( Card + driver version does matter while Nvidia sorts it out )
chuck@plexqa-av1:~$ dpkg -l | grep nvidia
ii libnvidia-cfg1-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-525 525.125.06-0ubuntu0.23.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.10-1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-525:amd64 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-525 525.125.06-0ubuntu0.23.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-525 525.125.06-0ubuntu0.23.04.1 amd64 NVIDIA binary Xorg driver
chuck@plexqa-av1:~$
logout
Connection to av1 closed.
[chuck@lizum ~.2000]$ gog dpkg -l | grep nvidia
ii gpustat 0.6.0-1 all pretty nvidia device monitor
ii libnvidia-cfg1-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535-server 535.54.03-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA Server Driver
ii libnvidia-fbc1-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535-server:amd64 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ml-dev:amd64 11.5.50~11.5.1-1ubuntu1 amd64 NVIDIA Management Library (NVML) development files
ii nvidia-compute-utils-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-cuda-dev:amd64 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development files
ii nvidia-cuda-gdb 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 11.5.1-1ubuntu1 amd64 NVIDIA CUDA development toolkit
ii nvidia-cuda-toolkit-doc 11.5.1-1ubuntu1 all NVIDIA CUDA and OpenCL documentation
ii nvidia-dkms-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA Server Driver metapackage
ii nvidia-firmware-535-server-535.54.03 535.54.03-0ubuntu0.22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535-server 535.54.03-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-opencl-dev:amd64 11.5.1-1ubuntu1 amd64 NVIDIA OpenCL development files
ii nvidia-profiler 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-utils-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA Server Driver support binaries
ii nvidia-visual-profiler 11.5.114~11.5.1-1ubuntu1 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
ii xserver-xorg-video-nvidia-535-server 535.54.03-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
[chuck@lizum ~.2001]$
Ahhhh you are using the server version, I didn’t think that would be the applicable instance. Let me try that. Otherwise, I’ll just roll it back to 525 and call it a day
