Transcoder fails due to lack of Notify space (edited)
The Patriot is working with transcoding. Eagle Eye is not. Eagle Eye is the one I’ve been testing with all this time that was hanging up at 33%
Now we can generate meaningful log files.
  1. Start the playback of the one which has trouble
  2. When it hangs / stops
  3. Stop playback
  4. Wait 20 seconds
  5. Download the logs ZIP and attach it.
Plex Media Server Logs_2021-06-11_02-30-22.zip (5.8 MB)
Any of my mkv with 5.1 True HD Audio are failing
  1. Wrong “Slash”
Jun 11, 2021 02:11:58.407 [0x7f245741cb38] ERROR - Error parsing allowedNetworks ' 192.168.7.0\0024': Invalid argument
Jun 11, 2021 02:11:58.407 [0x7f245741cb38] ERROR - Error parsing allowedNetworks ' 192.168.8.0\0024': Invalid argument
Should be: 192.168.7.0/24,192.168.8.0/24 No spaces
  1. Found the problem. – you placed a copy of Plex’s metadata in your media. NO NO
Plex on Ubuntu lives in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
Go check ( du -ms /var/lib/plexmediaserver – it should be a substantial number)
What you have here: /home/chris/server/movies/Library/Application Support/Plex Media Server/ and all below it… Does Not Belong.
It’s using up all the notification slots and blocking the transcoder with junk files.
How did you get Plex copied into your home directory?
Please show me the output of:
sudo systemctl status plexmediaserver
root@plex:/home/chris# du -ms /var/lib/plexmediaserver
12572   /var/lib/plexmediaserver
So delete the directory? `rm -rf /home/chris/server/movies/Library/Application Support/Plex Media Server/
One quick check to make sure you can.
It should not say anything about override.conf
As for what to delete, Delete Application Support and all below it.
If there are movie files in Library , move them to where they belong.
When Library is empty, remove it too.
After all cleaned up , Restart Plex
root@plex:/movies# sudo systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
     Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2021-06-11 02:11:51 UTC; 21h ago
    Process: 846 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, statu>
   Main PID: 893 (Plex Media Serv)
      Tasks: 82 (limit: 33595)
     Memory: 1.9G
     CGroup: /system.slice/plexmediaserver.service
             ├─  893 /usr/lib/plexmediaserver/Plex Media Server
             ├─ 1099 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-a1b1f3c10/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-ver>
             ├─ 1168 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.23.0.4497-a1b1f3c10 32600
             ├─ 1275 Plex EAE Service
             └─34092 /usr/lib/plexmediaserver/Plex Transcoder -codec:0 mpeg4 -analyzeduration 20000000 -probesize 20000000 -i /home/chris/server/movies/Courageous/Courageous.avi -filter_co>
Jun 11 14:12:21 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 15:12:21 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 16:12:20 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 17:12:21 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 18:12:22 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 19:12:21 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 20:12:22 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 21:12:22 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 22:12:23 plex Plex Media Server[893]: connect: Operation timed out
Jun 11 23:12:22 plex Plex Media Server[893]: connect: Operation timed out
root@plex:/movies#
root@plex:/movies# cd /home/chris/server/movies/Library
root@plex:/home/chris/server/movies/Library# ls
'Application Support'   linuxserver-chown.lock
Does that look correct to you?
That looks like you had the Ubuntu store “SNAP” package at one point ?
type snap list to confirm there is no Plex there.
type dpkg -l | grep -i plexm to confirm it’s there.
It also could be docker. (from LinuxServer.io)
sudo docker images
root@plex:/home/chris/server/movies/Library# snap list
Name    Version   Rev    Tracking       Publisher   Notes
core18  20210507  2066   latest/stable  canonical✓  base
lxd     4.0.6     20326  4.0/stable/…   canonical✓  -
snapd   2.50.1    12057  latest/stable  canonical✓  snapd
root@plex:/home/chris/server/movies/Library# dpkg -l | grep -i plexm
ii  plexmediaserver                        1.23.0.4497-a1b1f3c10              amd64        Plex organizes all of your personal media so you can easily access and enjoy it.
If you don’t have any media in /home/chris/server/movies/Library,
then erase from there down
sudo rm -rf /home/chris/server/Library
It looks to me like you have your media files in a different part of your home directory ?
My only media is on my NAS NFS mapped drives
I just changed the permissions to read only just to be safe.
root@plex:/home/chris/server/movies/Library# sudo rm -rf /home/chris/server/Library
root@plex:/home/chris/server/movies/Library# cd /home/chris/server/movies
root@plex:/home/chris/server/movies# ls
'#recycle'        'Michael Clayton'
'(500) Days of Summer'        'Mission Impossible Ghost Protocol'
'10,000 Black Men Named George'                                                               'Mouth to Mouth'
'10,000 Saints (2015)'        'Murder on a Sunday Morning'
'2 Fast 2 Furious (2003)'        "My Best Friend's Girl"
'2012 The End of the World'        'My Bloody Valentine'
'21 Jump Street'        'My Friend Dahmer (2017)'
'22 Jump Street (2014)'        'National Treasure 2'
'27 Dresses'        'Never Been Kissed (1999)'
'3 2 1 Frankie Go Boom'        'New World Order (2009)'
'310 to Yuma'        'New in Town'
'4Got10 (2015)'        'No Country for Old Men'
'500 MPH Storm (2013) [BluRay] [1080p] [YTS.AM]'                                              'No Reservations'
'911 Blueprint for Truth'        'Not Easily Broken'
'911 Chronicles Truth Rising'        'Notorious (2009) [Eng]'
'A Blade in the Dark (1983)'        'Now You See Me (2013)'
'A Glimpse Inside the Mind of Charles Swan III (2012)'                                        'Now You See Me 2 (2016)'
'A Good Day to Die Hard (2013)'                                                               "Ocean's Eleven"
'A Guy Thing (2003)'        "Ocean's Thirteen"
'A Night at the Roxbury (1998)'                                                               'Office Space'
'A Nightmare on Elm Street (1984)'                                                            'Old School (2003)'
'A Nightmare on Elm Street (2010)'                                                            'Oliver & Company (1988)'
'A Nightmare on Elm Street 2 Freddys Revenge (1985)'                                          'Out For A Kill'
'A Nightmare on Elm Street 3 Dream Warriors (1987)'                                           'Over the Hedge (2006)'
'A Nightmare on Elm Street 4 The Dream Master (1988)'                                         'P.S. I Love You'
'A Page Of Madness (1926)'        'Panic Room (2002)'
'A Promise (2013)'        'Paper Towns'
'A Real Vermeer (2016)'        'Parker (2013)'
'A Room with a View (1985)'        Passengers
'A Star Is Born (2018)'        Peacock
 AI_RecycleBin        'Personal Effects'
'Above The Law (1988)'        'Phoebe in Wonderland'
'Act of Valor (2012)'        'Phone Booth (2002)'
'After Darkness (2018)'        'Piercing (2018)'
'Air (2015)'        'Pineapple Express'
'All These Small Moments (2018)'                                                              'Pinup Dolls on Ice (2013)'
'Aloft (2014)'        'Pirates Of The Caribbean Dead Men Tell No Tales (2017)'
'American Conjuring (2016)'        'Pirates of the Caribbean - At Worlds End (2007)'
'American High School (2009)'        'Pirates of the Caribbean - Curse of the Black Pearl (2003)'
'American History X (1998)'        'Pirates of the Caribbean - Dead Man'\''s Chest (2006)'
'An Acceptable Loss (2018)'        'Pirates of the Caribbean - On Stranger Tides (2011)'
'An American Crime'        'Police State 4'
'Anna and the Apocalypse (2017)'                                                              'Powder Blue'
'Annapolis (2006)'        'Punisher War Zone'
'Aquaman (2018)'        Quarantine
'Aquaman Rage of Atlantis'        'Rachel Getting Married'
'Art of the Dynamic Handgun'        'Real Steel'
'At First Light (2018)'        Red
'Atomic Blonde (2017)'        'Reign Of The Supermen (2019)'
 Australia        'Remember Me (2010)'
 Avatar        'Riverhead (2016)'
'B Girl'        'Rockaway (2017)'
 Babel        'Run Fat Boy Run'
'Baby Mama'        'Russell Brand- Doing Life - Live'
'Bad Boys (1995)'        'S.W.A.T Firefight'
'Bad Boys II (2003)'        'S.W.A.T. (2003)'
'Bad Lieutenant Port of Call New Orleans'                                                     'SAW I UNRATED (2004)'
'Battle (2018)'        'SAW II UNRATED (2005)'
'Beautiful Boy (2018)'        'SAW III UNRATED (2006)'
'Beautiful Creatures (2013)'        'SAW IV UNRATED (2007)'
'Belly of the Beast (2003)'        'SAW V UNRATED (2008)'
'Best F(r)iends Volume 2 (2018)'                                                              'SAW VI UNRATED (2009)'
'Beverly Hills Chihuahua 2'        'SAW VII The Final Chapter UNRATED (2010)'
'Beyond Boundaries The Harvey Weinstein Scandal (2018)'                                       'Safe Haven (2013)'
'Beyond The Limit (1983)'        'Same Same But Different (2009)'
'Black Hawk Down'        'San Andreas (2015)'
'Blaze (2018)'        'Say Anything'
'Blood Bound (2019)'        'School for Scoundrels (2006)'
'Blood Diamond'        'Scrubs The Complete Fifth Season'
'Blood Slaughter Massacre (2013)'                                                             'Sea Monsters 2 (2018)'
'Blue Man Group'        'Seven Pounds (2008)'
'Body of Lies'        'Sex Drive (2008)'
'Bohemian Rhapsody (2018)'        'Sex and the City The Movie'
'Borat- Cultural Learnings of America for Make Benefit Glorious Nation of Kazakhstan (2006)'  'Shrek (2001)'
'Bound (2015)'        'Shrek 2 (2004)'
'Boy Erased (2018)'        'Shrek 4 (2010)'
'Boyhood (2014)'        'Shrek The Third (2007)'
'Brave (2012)'        'Shrek the Musical (2013)'
'Breaking In (2018)'        'Side Effects (2013)'
'Broken City (2013)'        'Silent Night, Deadly Night 2 (1987)'
 Brothers        'Silver Linings Playbook (2012)'
'Bumblebee (2018)'        'Smart House (1999)'
'Camp Fema American Lockdown'        Sniper
 Cars        'Sniper 2'
'Casino Royale'        'Sniper 3'
'Cast Away (2000)'        'Snitch (2013)'
'Category 6 Day Of Destruction'                                                               'Sons of Anarchy'
'Category 7 The End Of The World'                                                             'Soul Man (1986)'
'Charlie St Cloud'        'Soul Of The Game'
'Chasing Amy'        'Special Forces'
'Cherry Tree Lane (2010)'        'Spider-Man (2002)'
'Chupacabra Terror (2005)'        'Spider-Man 2 (2004)'
'Cinderella (1950)'        'Spy Game (2001)'
'Cinderella (2015)'        'Stand Up Guys (2012)'
'Cinderella And The Secret Prince (2018)'                                                     'Stealth (2005)'
'City Slickers (1991)'        'Step Brothers'
'Close (2019)'        'Step Up (2006)'
'Cloud Atlas (2012)'        'Step Up 2 The Streets'
'Con Air (1997)'        'Step Up 3'
 Conviction        'Step Up All In (2014)'
 Courageous        'Stick It (2006)'
 Crash        'Stigmata (1999)'
'Crazy (Hank Garland 2008)'        'Still Waiting'
 Cyrus        'Stomp The Yard 2 Homecoming'
'Dante'\''s Inferno An Animated Epic (2010)'                                                  'Stomp the Yard (2007)'
'Dead Like Me Life After Death (2009)'                                                        'Stopping Traffic (2017)'
'Deadpool (2016)'        'Struck By Lightning (2012)'
'Deadpool 2'        'Sunshine Cleaning'
'Defiance (2009)'        Surrogates
'Delicious (2013)'        'Sweet Home (2015)'
'Despicable Me'        Sweetland
'Destruction Los Angeles (2017)'                                                               Syriana
'Diary Of A Madman (1963)'        THIS_IS_GARTH_BROOKS_DISC1
'Django Unchained (2013)'        'That Gal... Who Was In That Thing That Guy 2 (2015)'
'Dogman (2018)'        'The Addams Family (1991)'
'Don'\''t Come Back From The Moon (2017)'                                                     'The Animal (2001)'
'Doom Room (2019)'        'The Art of Travel'
'Double Jeopardy (1999)'        'The Bank Job'
'Down To Earth (1994)'        'The Blind Side'
'Dr. Dolittle 2 (2001)'        'The Book of Eli'
'Driven To Dance (2018)'        'The Bourne Supremacy'
'Druid Peak (2014)'        'The Bourne Ultimatum'
'Drumline (2002)'        'The Boy Downstairs (2017)'
'Déjà Vu (2006)'        'The Breakfast Club (1985)'
'Eagle Eye'        'The Bridges of Madison County (1995)'
'Edge of Darkness'        'The Bucket List'
'End of Watch (2012)'        'The Butterfly Room (2012)'
'Enemy of the State (1998)'        'The Call (2013)'
'Entrapment (1999)'        'The Chronicles of Narnia -  Prince Caspian (2008) [1080p]'
'Escape From Planet Earth (2013)'                                                             'The Chronicles of Narnia - Voyage of the Dawn Tredder (2010)'
 Extract        'The Conjuring (2013)'
'Fabled Enemies'        'The Conjuring 2 (2016)'
'Failure to Launch'        'The Curious Case of Benjamin Button'
'Fall of the Republic'        'The Da Vinci Code'
'Fallen (1998)'        'The Dark Knight'
 Fanboys        'The Day the Earth Stood Still (2008)'
'Fantastic Beasts And Where To Find Them (2016)'                                              'The Den (2013)'
'Fast Five (2011)'        'The Departed'
'Fast and Furious (2009)'        'The Details (2011)'
 Faster        'The Devil We Know (2018)'
'Fatal Attraction (1987)'        'The Devil Wears Prada'
'Fifty Shades Freed (2018)'        'The Devil'\''s Rejects (2005)'
'Fifty Shades of Black (2016)'        'The Edge (1997)'
'Fifty Shades of Grey (2015)'        'The End of America'
'Fight Club'        'The Engagement Ring'
'Final Portrait (2017)'        'The Family Man (2000)'
'Fire Down Below'        'The Fast And The Furious'
 Fireproof        'The Fast and the Furious- Tokyo Drift (2006)'
'Firewall (2006)'        'The Fault In Our Stars'
'First Time Felon'        'The Gift (2015)'
'Flatliners (1990)'        'The Girl On A Motorcycle (1968)'
'Flubber (1997)'        'The Green Hornet'
'Fools Gold'        'The Grinch (2018)'
'Forgetting Sarah Marshall'        'The Guilt Trip (2012)'
'Freddy Vs Jason (2003)'        'The Half-Life Of Genius Physicist Raemer Schreiber (2017)'
'Freddys Dead The Final Nightmare (1991)'                                                     'The Hangover'
'Friday Night Lights (2004)'        'The Happening'
'Friday the 13th (1980)'        'The Highway Rat (2017)'
'Friday the 13th A New Beginning (1985)'                                                      'The Hobbit An Unexpected Journey (2012)'
'Friday the 13th Part 2 (1981)'                                                               'The Hobbit The Battle of the Five Armies (2014)'
'Friday the 13th Part III (1982)'                                                             'The Hobbit The Desolation of Smaug (2013)'
'Frost Nixon'        'The Holiday'
'Frozen River'        'The Incredible Hulk'
'Fun with Dick and Jane (2005)'                                                               'The International'
'Furious Seven (2015)'        'The Last Man (2018)'
'Fyre Fraud (2019)'        'The Last Ride (2011)'
'Gangster Squad (2013)'        'The Last Stand (2013)'
'Garth Brooks Central Park'        'The Legend Of Secret Pass (2019)'
'Garth Brooks Dublin'        'The Legend of Bagger Vance (2000)'
'Garth Brooks Video Collection'                                                               'The Life Before Her Eyes'
'Generation Um (2012)'        'The Lion King 1 and a half'
'Geostorm (2017)'        'The Lion King 2'
'Get Smart'        'The Lion King 2 Simba'\''s Pride (1998)'
'Ghost Town'        'The Lion King 3 (2004)'
'Glass (2019)'        'The Lord of the Rings The Fellowship of the Ring THEATRICAL EDITION (2001)'
'Good Luck Chuck'        'The Lord of the Rings The Return of the King EXTENDED (2003)'
'Gosnell The Trial Of America'\''s Biggest Serial Killer (2018)'                              'The Lord of the Rings The Two Towers (2002)'
'Gran Torino (2009)'        'The Mask (1994)'
 Greys        'The Maze Runner (2014)'
'Greys Anatomy Season 5'        'The Mechanic'
'Grown Ups (2010)'        'The Meg (2018)'
'Grown Ups 2 (2013)'        'The New Romantic (2018)'
'Hall Pass'        'The Notebook'
'Halloween (1978)'        'The Numbers Station (2013)'
'Halloween II (1981)'        'The Nutcracker And The Four Realms (2018)'
'Halloween II (2009)'        'The Obama Deception (2009)'
'Halloween III Season of The Witch (1982)'                                                    'The Patriot'
'Halloween UNRATED (2007)'        'The Plague Dogs (1982)'
'Hancock (2008)'        'The Prestige (2006)'
'Hard Candy'        'The Punisher'
'Harry Potter and The Deathly Hallows Part 2 (2011)'                                          'The Pursuit of Happyness'
'Harry Potter and the Chamber of Secrets (2002)'                                              'The Quick and the Dead'
'Harry Potter and the Deathly Hallows Part 1 (2010)'                                          'The Realm (2018)'
'Harry Potter and the Goblet of Fire (2005)'                                                  'The Ring [Duology]'
'Harry Potter and the Half Blood Prince (2009)'                                               'The Rise And Fall Of A White Collar Hooligan 2 (2013)'
'Harry Potter and the Order of the Phoenix (2007)'                                            'The Road To El Dorado (2000)'
'Harry Potter and the Prisoner of Azkaban (2004)'                                             'The Score'
'Harry Potter and the Sorcerers Stone (2001)'                                                 'The Seagull (2018)'
'Havana (1990)'        'The Seige'
'Hellboy II The Golden Army'        'The Shape Of Water (2017)'
'Henry Poole Is Here'        'The Sisterhood of the Traveling Pants'
'Hide and Seek (2005)'        'The Sisterhood of the Traveling Pants 2'
'Hitch (2005)'        'The Sisters Brothers (2018)'
 Hop        'The Social Network (2010)'
'How To Lose A Guy In 10 Days'        'The Standoff At Sparrow Creek (2018)'
'How To Train Your Dragon (2010)'                                                             'The Strangers (2008)'
'How to Train Your Dragon 2 (2014)'                                                           'The Strangers Prey At Night (2018)'
'Hulk (2003)'        'The Terrorists (1975)'
'Hunter Killer (2018)'        'The Tracey Fragments'
'Hustle & Flow (2005)'        'The Transformers- The Movie (1986)'
'I Am Legend (2007)'        'The Truman Show (1998)'
'I Hate Kids (2019)'        'The Twilight Saga Breaking Dawn Part 1'
'I Love You, Beth Cooper'        'The Twilight Saga Eclipse'
"I've Loved You So Long"        'The Twilight Saga New Moon'
'I.T. (2016)'        'The Uninvited'
'IO (2019)'        'The Village'
'Identity (2003)'        'The Vow'
'Identity Thief (2013)'        'The Water Horse Legend of the Deep'
'In The Line of Fire (1993)'        'The Wife (2017)'
'Independence Day'        'The Women'
'Indiana Jones and the Kingdom of the Crystal Skull'                                          'The Zookeepers Wife'
'Indivisible (2018)'        'Thick as Thieves'
'InfoWars Collection Vol 4'        'This is Garth Brooks'
'Inglourious Basterds'        'Top Gun (1986)'
'Inside Man'        Transformers
'Interview With A Hitman (2012)'                                                              'Transformers Revenge of the Fallen'
'Ira & Abby'        'Transporter 3 (2008)'
'Iron Eagle (1986)'        'Trapped In Paradise (1994)'
'Iron Man'        'Tron Legacy'
'Iron Man & Hulk Heroes United (2013)'                                                         Twilight
'Jack Reacher (2012)'        'Twisted (2018)'
'Jackass Two'        'Two Can Play That Game'
 Jericho        'Two Lovers'
'John Carter'        'Under The Tree (2017)'
'Journey to the Center of the Earth'                                                          'Underdog (2007)'
 Juno        'Underworld Rise of the Lycans'
'Killer High (2018)'        'United 93 (2006)'
'King Of Crime (2018)'        'Unseen Enemy (2017)'
'King Of Thieves (2018)'        Unstoppable
'Knocked Up'        Up
'Lady In The Water (2006)'        'Valentine'\''s Day (2010)'
'Lakeview Terrace'        'Vampire Hookers (1978)'
'Last Chance Harvey'        'Van Wilder'
'Leave It To Beaver'        'Venom (2018)'
'Left Behind'        'Volcano (1997)'
'Left Behind 2 Tribulation Force'                                                              W
'Left Behind 3 World at War'        'Walk the Line (2005)'
'Let'\''s Be Cops (2014)'        'Wall Street Money Never Sleeps'
'Lethal Weapon (1987)'        Wall-E
'Lethal Weapon 2 (1989)'        Wanted
'Lethal Weapon 3 (1992)'        'Warm Bodies'
'Lethal Weapon 4 (1998)'        'We Are Marshall (2006)'
'Lone Survivor (2013)'        'Western (2017)'
'Lord of War (2005)'        'What Happens in Vegas'
'Lottery Ticket'        'What If'
'Love & Debt (2018)'        'What Just Happened'
'Love Happens (2009)'        'What Maisie Knew'
'Love Sick Love (2012)'        'Whip It'
'Love and Other Drugs'        'White House Down'
'Magpul Dynamics - Art of Tactical Carbine Volume 2'                                          'White Irish Drinkers (2010)'
'Magpul Dynamics - The Art of the Tactical Carbine DVDRip'                                    'Wildcats (1986)'
'Maleficent (2014)'        'Win a Date With Tad Hamilton!'
'Mama (2013)'        'Windrock 2016'
'Man on Fire (2004)'        'Yes Man (2008)'
'Marley & Me (2008)'        'You Got Served (2004)'
'Matangi Maya M.I.A. (2018)'        Zapped
 McFarland        'Zipper (2015) [1080p]'
'Meet Dave'        'i, Robot'
'Meet the Fockers (2004)'        movies
'Men Women and Children'        music
'Men in Black 3 (2012)'        photos
'Men in Black II'        recordedtv
'Men of Honor (2000)'        tv
'Mental (2012)'
Good
Now, something you can eventually do to get things out of your home directory –
(Plex really has no reason to be there)
sudo mkdir /home/movies /home/tv
chown chris.chris /home/movies /home/tv
If you have your NAS shared folders mounted in your home directory, you can change the mounting points to be /home/movies, etc.
You’ll still have the same access because we just set you as owner.
This is something you can work towards – “Next Lession” stuff :slight_smile:
IF you’re sure Library only contains old PMS internal stuff
THEN delete it and all below it rm -rf /home/chris/server/movies/Library
Lastly, restart PMS
That sounds good. This VM is literally only ever going to run Plex. I don’t want to add anything else to it that would potentially complicate matters.
root@plex:/home/chris/server/movies# cd /home/chris/server/movies/Library
bash: cd: /home/chris/server/movies/Library: No such file or directory
successfully deleted
Fair enough. However you want it.
At some point, you’ll want hardware access in the VM for HW transcoding (if you haven’t done that passthrough yet)
It’s not hard to do in ESXi but , for me, meant I had to turn off the onboard HDMI adapter :frowning:
Restart PMS.
Let it run for 2 minutes
Download the logs.
Let’s make sure it’s all clean again.
I haven’t done any GPU transcoding. I don’t have one installed. I would like to at some point if I can find one that will fit and work in the R710.
My 1070’s are mining
There is no AMD GPU support yet.
It’s on the list to do … along with 1000 other things :confused:
