Server Version#: 1.25.8.5663
Player Version#: Web
Heya!
Trying to convert some of my 4K HDR H265/HEVC media via the “Original Quality” setting, however the Console is constantly throwing the following, at the bottom attached lines over and over again.
One thing that stands out is the “Cannot allocate memory” error, which is weird since my Server has 16GB RAM allocated where the Transcoder uses roughly 3.2GB and in general everything on it (including Plex) uses ~9-10GB. CPU specs are 24 Cores with 2x Intel Xeon E5645.
I may actually be running into the Transcoder’s 32bit application RAM limits here while trying to encode this particular file, from the looks of it. Or do you guys maybe have another guess what this could be?
Mar 27, 2022 11:29:04.617 [16236] Error — [Transcoder] [hevc @ 01203f40] Could not find ref with POC 72
Mar 27, 2022 11:29:05.456 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:06.410 [17176] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:06.414 [17176] Error — [Transcoder] [hevc @ 01203f40] Could not find ref with POC 7
Mar 27, 2022 11:29:07.260 [11712] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:07.361 [11712] Error — [Transcoder] [hevc @ 01202b00] Could not find ref with POC 22
Mar 27, 2022 11:29:08.160 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:08.962 [17176] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:11.926 [11712] Error — [Transcoder] [hevc @ 01203f40] Could not find ref with POC 6
Mar 27, 2022 11:29:11.926 [11712] Error — [Transcoder] [hevc @ 01203f40] Error constructing the frame RPS.
Mar 27, 2022 11:29:12.011 [17176] Error — [Transcoder] [hevc @ 01202b00] Could not find ref with POC 6
Mar 27, 2022 11:29:12.710 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:12.711 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:13.779 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:15.444 [11712] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:17.359 [16236] Error — [Transcoder] [hevc @ 01203f40] Could not find ref with POC 12
Mar 27, 2022 11:29:18.161 [11712] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:18.297 [11712] Error — [Transcoder] [hevc @ 01202b00] Could not find ref with POC 24
Mar 27, 2022 11:29:18.534 [16236] Error — [Transcoder] [hevc @ 01201b00] get_buffer() failed
Mar 27, 2022 11:29:18.535 [16236] Error — [Transcoder] [hevc @ 01201b00] thread_get_buffer() failed
Mar 27, 2022 11:29:19.100 [16236] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
Mar 27, 2022 11:29:19.105 [16236] Error — [Transcoder] [hevc @ 01203f40] Could not find ref with POC 42
Mar 27, 2022 11:29:19.320 [17176] Error — [Transcoder] Error while decoding stream #0:0: Cannot allocate memory
