Error "The transcoder exited due to an error." even after reinstall
I have been having an headache in getting a recent anime series I have to work. I have wiped my plex server including registry, plex folder etc… in an effort to solve this problem and it does not work. The series runs largely fine until the end ~5min of each show when the transcoder fails somewhat randomly (no specific frame) with error “Conversion failed. The transcoder exited due to an error.”. I reviewed the logs and I believe the error is associated with this fault below, as it’s my only “Error” in the logs.
The file has various subtitles and audio streams being an anime (Japanese + English etc…) otherwise the copy is fine and play well using a traditional player, plex struggles for unknown reasons.
Error points to possible memory issue, my computer has plenty of memory available (16gb). Notably it is running Windows 11 22000.120 (not sure if that matters) w/ i7-8700k/1080 TI
[14776] DEBUG - [Now] Device is Firefox (Firefox).
[14776] DEBUG - [Now] Profile is Firefox
[14776] DEBUG - [Now] Updated play state for /library/metadata/3806.
[14776] DEBUG - Statistics: (5s4yaoiw8gj5oga5acyezbjd) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
[9956] DEBUG - Completed: [127.0.0.1:57746] 200 GET /:/timeline?ratingKey=3806&key=%2Flibrary%2Fmetadata%2F3806&playbackTime=12910&playQueueItemID=54&state=playing&hasMDE=1&context=library%3Acontent.library&row=2&col=0&time=2916000&duration=3001000 (10 live) GZIP 3ms 750 bytes (pipelined: 1)
[1372] ERROR - [Transcoder] Error while filtering: Cannot allocate memory
[1372] ERROR - [Transcoder] Failed to inject frame into filter network: Cannot allocate memory
[1372] ERROR - [Transcoder] Error while processing the decoded data for stream #0:0
[8580] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe’ exit code for process 21224 is 1 (failure)
[6284] DEBUG - Streaming Resource: Terminating session 07411700:dx6yunqknwjcvgfyfdkkot3k which is using transcoder slot. Used slots is now 0
[6284] DEBUG - Streaming Resource: Terminated session 07411700:dx6yunqknwjcvgfyfdkkot3k with reason Conversion failed. The transcoder exited due to an error.
[15896] DEBUG - Killing job.
[15896] DEBUG - Job was already killed, not killing again.
[15896] DEBUG - Stopping transcode session oq46epcqnt7pr2pampmpj0sg
[15896] DEBUG - Transcoder: Cleaning old transcode directories.
[15896] DEBUG - Transcoder: Cleaning old transcode directory: “C:\Users*******\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-oq46epcqnt7pr2pampmpj0sg-5b62f58a-e08e-4b17-8e80-7a29d4a89c2d”
[9776] DEBUG - Auth: authenticated user 1 as **********
Same issue here. Any input Support Team?
