Transcoding a single file put CPU at 100%
Server Version#: Version 1.41.5.9522
Player Version#: various IOS versions all up to date
My hardware :
  • CPU : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
  • 32Go of RAM
  • 2x2To HDD
I also installed ffmpeg.
Hello all,
I recently made a fresh install of my linux server (Debian 12) hosting my plex media server. On the previous install, everything worked fine. I was able to have 4 simultaneous transcode sessions without any issue or lag.
Now, after having reinstalled all the system including PMS, when only trying to play a single file using transcode, my CPU usage is stuck at 100% and the bandwith usage is put at its maximum.
And in addition, the video is lagging with a stop every 2sec.
and the info is the following, it is a simple h264 file in 1080p that worked perfectly fine before.
The hardware of my server stayed the same excepted the replacement of a HDD (similar)
My transcoder settings are the following :
  • quality : high speed prefered
  • buffer size : 30s
  • H264 presets : super fast
  • HDR tone : activated
  • hardware acceleration : true
  • encoding via hardware : true
In the distant access section I did not set any limitation for the bandwith, and for the limitation of the distant flux I tried both original and a limitation at 8Mbit/s (1080p).
I also tried a htop before and during a play event (before, CPU usage is aroung 3%)
As you can see below, it is taking all ressources…
I’m honestly lost, so if any one have some clue to solve this issue I would be pleased to read it.
Your CPU does not have HW acceleration support
Do you have an external Nvidia GPU which isn’t being seen / selected ?
(Settings - server - Transcoding - SHOW ADVANCED)
Hello,
thanks for the reply, looking back at the option I put the following
Knowking that I let the option on Auto.
The very strange thing, is that I had a serious improvment after renaming the server. After the install, I renamed it the same way as the old one. After simply putting a 2 in the name to change it, consumtion dropped down…
However things are better, there is still a high load on the CPU with a simple h264 1080p transcode…
Gemini Lake CPUs are fickle
I’ve had to manually select the UHD 600 GPU for it to work right
My bad I picked the second server I have (on Synology NAS).
For the Debian server on Intel XEON
so does it mean that I have to uncheck the hardware acceleration option?
Hello
I’m still struggling with the processor consumption of my server since my fresh install.
A single transcode from a 1024p h264 source eat 80% of the processor… we are really far away from the previous behavior… showing approx 15 to 20% max
If you have any clue on a possible issue…
Thanks beforehand
Which Xeon Syno do you have ?
I ask because there are some Syno systems now which support external Nvidia GPU.
One thing we’re hoping for is better CPU support with FFMPEG 6.1
