Please provide what you have in the Logs directory as a tar.gz (gzipped tarball)
There will be data there
Here you go: plex.logs.tar.gz
Are you 100% certain it’s not overheating…
I mean, I guess it’s possible, though it seems unlikely. I used the same machine for FPGA/ASIC place and route software before it was the media server, and that pegged all the cores for days at a time, and it was rock-solid. There’s no stress-test quite like running P&R for an ASIC…
Here’s what I see from ‘sensors’:
[simon@xanadu]$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +41.4°C (high = +70.0°C)
k10temp-pci-00cb
The high being set to 70 implies that this is the without-offset value.
The machine is mounted in a 3U case in the garage, with 4 (high pressure and very loud) fans blowing through the case. On top of that, the CPU cooler is water-cooled, and the radiator for the water-cooler is directly in the path of all that air being blown.
Again, I guess it’s possible, but I rarely see the temp get above 50, even on a hot (100 degrees F) day. I’ll set up some temperature-monitoring scripts and poll it every 30 seconds or so, then start up transcoding again. If I can, I’ll try that this evening.
If it’s a system library, is there any good way to try and track it down ? Or is a ‘re-install everything from scratch’ the only sure way ? In the latter case, I’d appreciate some tips on how you migrate the current Plex state to a new machine instance - there’s already a lot of time invested in getting to where I am that I’d hate to throw away…
I did think about using hardware encoding to offset the problem, but this is an AMD machine running Linux, and I wasn’t sure if putting my 980Ti GPU in there would be supported - I’ve read various conflicting reports of hardware encoding being supported/not-supported under Linux…
Cheers
Simon
