Transcoding error when playing video files with preloaded subtitles
@chrisallen Would you advice me to wait for you guys to patch this, or is there anything else I can try?
If it helps, I can provide you temporary SSH and or Plex access.
Let’s move to a DM to try and fix the issue. I will be available tomorrow to assist
I would like to know the solution as well. Tried setting environmental variables, restarted and without any luck.
@ChuckPa would you mind working with the users to run a script to manually fix the broken post-migration absolute symlinks? thanks :slight_smile:
I’ve been playing with some scripting code in preparation for fixing broken links after migration (this exact situation) and be able to resolve them during migration.
I would like to request a little bit of info on what those links actually look like.
I’m willing to take this to PM if you prefer. Please let me know.
Otherwise, what I ask is simple:
  1. Find one of those absolute path symlinks (readlink Filename )
  2. Show me the path to the symlink and the path to where it thinks it’s pointing.
This will confirm what I think has happened.
If I’m right, the rest is little bit of ScriptFu and then run the script on your existing PMS installations.
Hey ChuckPa,
Could you send me a PM so I can reply on that?
What would be the easiest way to get this info?
  1. Find one of those absolute path symlinks ( readlink Filename )
If it is easier for you I can provide Teamviewer or SSH Access.
Thanks in advance
Edit 20-1-2021:
I notice that some of my movies and shows also don’t show a poster anymore. When manually trying to select one this happens. Not sure if this related to the same issue source.:
@ChuckPa
I have gone ahead and delete all .srt files in /volume1/@apphome/PlexMediaServer/Plex Media Server/Media/localhost and subfolders.
I’ll see how this goes.
I do however still have the issue with posters not loading for some movies and series, with above screenshot as example. Any idea what that could be?Plex Media Server Logs_2021-01-21_16-05-25.zip (5.2 MB)
Hi Trumpy81!
You solved my plex problems!
Thx :smiley:
After great help from Chuck the problem seems resolved for me. Sub-zero plugin was the root cause and Chuck helped me find and fix incorrect files.
