Have PMS running on NAS and using the HDHomeRun. When a recorded program is viewed at about 1minute and a half the picture
breaks up, whats going on here?
We need Plex Media Server.log and Plex Tuner Service.log to see why this is occurring.
Comon’ This is a known issue with DVR…
Are you saying Plex cannot duplicate this??
If Not…
Might I suggest a test case?
Start a couple remote streams requiring transcoding (possibly 1080p files that will require bitrate reduction)
Then start a couple recordings.
You will probably see the issue just fine. Recording failures and recordings with artifacts.
This behavior has been reported MANY times as well as logs supplied in the past.
@lenhood
What sort of box is your PMS running on??
Yeah I found an old tread from the past, where I was told to turn off transcoding and that worked, I have it off at the HDHomeRun, but no way to turn it off on PMS…
Sent from my iPhone
