Transcoding LiveTV fails, hevc errors
Server Version#: v1.15.3.876
Player Version#: 1.40.1 (11962) Apple TV 4K
I’m using a HDHomeRun DUO for DVB-T2 with the latest version of Plex on Linux. While streaming Live TV to VLC works as expected, i can’t get any video or audio to work with Plex (not with the ATV App and not within a browser). Judging from the logs some issue with transcoding occur.
Any ideas how to debug or solve this?
Thanks!
Apr 09, 2019 00:48:23.438 [0x7f2d6412f700] INFO - Plex Media Server v1.15.3.876-ad6e39743 - Debian GNU/Linux PC x86_64 - build: linux-x86_64 debian - GMT 00:00
Apr 09, 2019 00:48:23.438 [0x7f2d6412f700] INFO - Linux version: 9 (stretch), language: en-US
Apr 09, 2019 00:48:23.438 [0x7f2d6412f700] INFO - Processor Intel(R) Xeon(R) CPU E3-1260L v5 @ 2.90GHz
Apr 09, 2019 00:48:23.438 [0x7f2d6412f700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 09, 2019 00:48:23.471 [0x7f2d71357740] INFO - OCSP: Successfully retrieved response from cache.
Apr 09, 2019 00:48:25.386 [0x7f2d6312d700] INFO - SQLITE3:(nil), 283, recovered 400 frames from WAL file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.providers.epg.onconnect-8af5a221-4ab7-4663-9c48-dd393658368f.db-wal
Apr 09, 2019 00:48:25.437 [0x7f2d537fe700] WARN - Crash: Crash reporting disabled
Apr 09, 2019 00:48:26.166 [0x7f2d51779700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Apr 09, 2019 00:48:26.171 [0x7f2d16ff5700] WARN - Sync: local sync directory "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+" does not exist
Apr 09, 2019 00:48:28.387 [0x7f2d53fff700] WARN - OnConnect: No match for detailed movie version: 12486939 MV008428390000
Apr 09, 2019 00:48:31.081 [0x7f2d527fc700] INFO - Refreshing paths watched by LibraryUpdateManager
Apr 09, 2019 00:48:34.586 [0x7f2d6192a700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Apr 09, 2019 00:48:42.234 [0x7f2d357fa700] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Apr 09, 2019 00:48:43.599 [0x7f2d537fe700] ERROR - Unable to find title for item of type 5
Apr 09, 2019 00:48:46.262 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.263 [0x7f2d357fa700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.264 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.264 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.265 [0x7f2d357fa700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.265 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.335 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.335 [0x7f2d357fa700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.397 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.398 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.398 [0x7f2d357fa700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.399 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:48:46.399 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.400 [0x7f2d357fa700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.400 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:48:46.401 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.689 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.690 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.702 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] The cu_qp_delta 32 is outside the valid range [-26, 25].
Apr 09, 2019 00:49:02.704 [0x7f2d1bfff700] ERROR - [Transcoder] nb_cpb 0 invalid
Apr 09, 2019 00:49:02.704 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.705 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.705 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.706 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.706 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.706 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.707 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.707 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.708 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.708 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.708 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.709 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.709 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.710 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.710 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.710 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.711 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.711 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.712 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.712 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.712 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.713 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.713 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.714 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.714 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.714 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.715 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 0
Apr 09, 2019 00:49:02.715 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.715 [0x7f2d1b7fe700] ERROR - [Transcoder] [hevc @ 0x2554a00] PPS id out of range: 1
Apr 09, 2019 00:49:02.719 [0x7f2d1bfff700] ERROR - [Transcoder] [hevc @ 0x2554a00] Invalid delta in scaling list data: 6.
Apr 09, 2019 00:49:07.705 [0x7f2d1bfff700] ERROR - [Transcoder] [stream_segment,ssegment @ 0x4a85e80] sample rate not set
Apr 09, 2019 00:49:07.705 [0x7f2d1b7fe700] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Apr 09, 2019 00:49:07.706 [0x7f2d1bfff700] ERROR - [Transcoder]
Apr 09, 2019 00:49:07.781 [0x7f2d34ff9700] ERROR - DVR:Subscription: Rolling media grab failed to start.
Apr 09, 2019 00:49:07.788 [0x7f2d60928700] ERROR - Unknown metadata type:
