Server Version#: 1.25.9.5721-965587f64
I followed the instruction from this link: PLEX on QNAP NAS | How to use a 3rd Party GPU to Hardware Transcode on Plex (Plex Pass required) - YouTube Please note that I Plex Flex Subscriber
Thanks in advance
@SnowlilyDr
Do you have both /dev/dri/renderD128 and renderD129?
One thing shown in the video is where he edits the file while Plex is running.
It is recommended to Stop Plex first then perform the edit. Restart after saving.
It’s a good idea to confirm HardwareDevicePath="/dev/dri/renderD129" is listed in side the scope of /> and that it exists in /dev/dri.
Also confirm the GPU is in “QTS” or “QuTS” mode and not assigned to a Container or VM.
Thank You! for quick response. Yes, configuration was updated on the Preferences.xml please screen shots:
would you please make certain DEBUG logging is enabled and then recreate the playback attempt.
I’d like to see the interaction between PMS and the GPU
Download the logs and attach the ZIP file please
