Transcoding sessions directory not found after rebuild
Server Version#: Version 1.14.1.5488
Player Version#:all
I accidentally deleted a perfectly functional Plex-Server container. When I brought the image back up, I it appears that it is in a odd state where some videos won’t work. The console error is:
Couldn’t find the file to stream: /transcode/Transcode/Sessions/plex-transcode-ptzv6rhkya8i4dng08juvkv7-35a9e02d-bd68-4935-9deb-9cbab71d2773/init-stream0.m4s,/transcode/Transcode/Sessions/plex-transcode-ptzv6rhkya8i4dng08juvkv7-35a9e02d-bd68-4935-9deb-9cbab71d2773/chunk-stream0-00529.m4s
In the container, the directory /transcode is there with space, but the sub-directory Transcode/Sessions is not:
Filesystem 1K-blocks Used Available Use% Mounted on
overlay 912353804 124453140 741532716 15% /
tmpfs 6117244 0 6117244 0% /sys/fs/cgroup
/dev/sda2 1864685168 564099044 1205842528 32% /swimvids
udev 6082752 0 6082752 0% /dev
shm 65536 8 65528 1% /dev/shm
/dev/sdb1 912353804 124453140 741532716 15% /transcode
/dev/sda3 1012855788 786431176 174951460 82% /data
My guess is that /transcode was a stateless container directory and some statefull database is expecting those files to be there.
Any suggestions on how I can fix it?
The root cause of this is I picked up an old:
plex:
image: linuxserver/plex:latest
instead of -->
plex:
image: plexinc/pms-docker:plexpass
Needed the later… everything worked again fine after that!
