Transfer failed!
Server Version#:1.42.2.10156
Player Version#:2025.31.1
I am getting a ‘Transfer failed’ after a 22% download of the media. Both the server and client are on LAN.
Server DEBUG logs ZIP file which captures this ?
We can’t help solve without them.
Here is the log
Plex Media Server.zip (432.4 KB)
I’m not seeing anything .. no download or failure.
Can you please recreate and provide the entire ZIP (all rollover files included) ?
Please also share the time and filename ?
I have uploaded the zip file here.
The file is Big Buck Bunny and you can see the download percentage at line 7209 in Plex Media Server.log
@rajil_s
Would you PLEASE STOP editing the ZIP file which PMS gives you ???
It should be about 4.x MB in size.
You don’t need upload it outside the forum.
After I read it, I will remove it if you like.
It’s trying to transcode Big Buck Bunny on an unidentified Nvidia GPU.
Which model number GPU do you have?
What does nvidia-smi return ?
nvidia-smi
Fri Dec 19 22:19:51 2025
| NVIDIA-SMI 580.105.08             Driver Version: 580.105.08     CUDA Version: 13.0     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  Quadro P2000                   Off |   00000000:01:00.0 Off |                  N/A |
| 55%   51C    P0             19W /   75W |    1083MiB /   5120MiB |      1%      Default |
|                                         |                        |                  N/A |
I tried to download (and failed) another video which does not involve transcoding.
Plex Media Server Logs_2025-12-19_22-22-47.zip (2.8 MB)
Would you please repeat again with Plex/web ?
  1. Restart the server
  2. Play (transcode) Big Buck Bunny using Plex/web
  3. Stop after 20 seconds
  4. Download it
  5. Download and attach the logs
Actually, if you are having download issues, the client logs may be more useful.
