Troubleshooting dropped frames on android
Switching to AC5.1 helped a little, just odd this is a problem on a modern player from Google. Never had an issue with Roku. Then the bug Google mentioned. What’s up with that?
That overlay tells the whole story—there are two specific bottlenecks causing those 869 dropped frames:
  1. Software Audio Decoding (Plex.Audio.DCA): Your rip uses a 6-channel DTS (DCA) track, and the Google TV Streamer does not have hardware DTS decoding. Plex is decoding it in software on the Streamer’s CPU while simultaneously pushing a massive 64.2 Mbps 4K HEVC stream through c2.mtk.hevc.decoder, starving the video pipeline.
  2. Refresh Rate Mismatch (23.98fps vs 60.00Hz): Your Display panel shows 3840x2160 @ 60.00Hz while the video is 23.98fps, forcing the MediaTek decoder/compositor to do real-time frame-rate conversion on a 191 Mbps peak bitrate stream.
Step-by-Step Fix (Do These in Order)
1. Stop Software DTS Decoding (Biggest Impact)
Because your TV or soundbar isn’t accepting raw DTS passthrough (causing Plex to fall back to Plex.Audio.DCA), you need to either switch tracks or let your server convert the audio instead of the Streamer’s CPU:
  • Switch the audio track first: On the playback screen in your photo, press Down on your remote → select the Gear icon → Audio (or Streams) → pick a Dolby Digital (AC-3 5.1) or AAC track if the rip has one.
  • Force server-side audio transcoding: If DTS is the only track, go to the Plex Home Screen → select your Profile Icon (top left) → Settings → Advanced → Passthrough → set to Disabled. This tells Plex Media Server to convert the DTS track into a format the Streamer handles in hardware, freeing up the Streamer’s CPU.
2. Match Your Display Refresh Rate to 23.98Hz
  1. From the Google TV Home Screen, go to Settings (gear icon, top right) → Display & Sound → Match content frame rate → select Always (or Non-seamless). [1]
  2. Open Plex → Profile Icon → Settings → Advanced → toggle Refresh Rate Switching to On.
    (When playing properly, the Display box in your overlay will change from 60.00Hz to 23.98Hz or 24.00Hz.)
3. Eliminate the c2.mtk.hevc.decoder Frame-Drop Bug
The MediaTek MT8696 chip inside the Google TV Streamer has a documented Android MediaCodec bug (c2.mtk.hevc.decoder) that delivers high-bitrate 4K HEVC frames late in ExoPlayer-based apps like Plex: [1]
  • Quick check: Install VLC or Kodi (with the Plex add-on) from the Google Play Store on your Streamer and play the exact same file. Those apps use FFmpeg/custom media pipelines that bypass the c2.mtk.hevc.decoder timing bug on 4K remuxes.
  • Alternative Plex client: Many Google TV Streamer users switch to Plezy for high-bitrate 4K Blu-ray remuxes, as it connects directly to your Plex server without triggering the official Plex app’s frame-pacing drops. [1, 2]
If switching the audio track and enabling Refresh Rate Switching doesn’t drop that counter to zero, let me know:
  • Your audio setup (TV speakers, soundbar, or AV receiver, and how it’s connected)
  • What Plex Media Server hardware you’re running (NAS, PC, etc.)
That rules out the audio decoder—the culprit is Plex’s ExoPlayer implementation on the Google TV Streamer choking on high-bitrate 4K HEVC remuxes (64+ Mbps) and failing to trigger your TV’s non-seamless refresh rate switch.
Notice in your screenshot that even with Google TV’s Match content frame rate set to Always, the Display panel still reads 3840x2160 @ 60.00Hz. On displays that don’t support HDMI 2.1 QMS (seamless switching), Plex’s Android TV client frequently fails to hand off the non-seamless refresh rate change to the OS, leaving the MediaTek hardware decoder (c2.mtk.hevc.decoder) dropping frames at 60Hz.
1. Force 24Hz Manually (Quickest Verification)
Before changing apps, verify if the frame drops are strictly from the 60Hz mismatch or the Plex player itself:
  1. Go to Google TV Settings (gear icon) → Display & Sound → Resolution (or Advanced display settings → Resolution).
  2. Manually select 4K 24Hz (or 4K 23.98Hz).
  3. Play the movie in Plex and check the Frames counter. If it still drops frames at 24Hz, the bottleneck is Plex’s ExoPlayer build on the Streamer—a widespread issue reported by Google TV Streamer owners on Reddit across high-bitrate files.
2. Switch to an Alternative Player (Permanent Fix without Switching Inputs)
Because the official Plex Android TV app relies on a rigid ExoPlayer pipeline that struggles with 60–190 Mbps UHD Blu-ray peaks on MediaTek chips, switching the playback engine fixes both the frame drops and the non-seamless 24Hz handshake:
  • Option A: Kodi + PlexKodiConnect (Best for 4K UHD Remuxes)
    1. Install Kodi from the Google Play Store on your Streamer.
    2. In Kodi, go to Settings (gear icon) → System → Display → Whitelist and check 3840x2160p @ 23.98Hz and 24.00Hz.
    3. Go to Settings → Player → Videos → set Adjust display refresh rate to On start / stop (this forces the non-seamless HDMI handshake to 23.98Hz).
    4. Connect your Plex library via PlexKodiConnect (or the official Plex add-on in Kodi’s repository). Kodi’s VideoPlayer buffers and paces 4K HEVC remuxes cleanly with zero dropped frames.
  • Option B: Plezy (Lighter Plex-Native Client)
    Install Plezy on your Streamer. It uses an mpv-based backend (with an ExoPlayer fallback toggle in Settings) that handles high-bitrate MKV remuxes and non-seamless refresh rate switching much more reliably than the official Plex client.
(Note: Remember to set your Google TV resolution back to 4K 60Hz if you manually changed it in Step 1 so your menus stay smooth.)
If you test manual 4K 24Hz or Kodi/Plezy, let me know:
  • Whether the Frames (dropped) counter stops climbing
  • What TV model you’re connected to (to check if an HDMI port setting like Enhanced Format / Input Signal Plus is throttling bandwidth)
