TrueHD transcoding not working
Server Version#: 1.32.5.7349
Player Version#: Android 9.27.0.2856
Kudos for this version of PMS finally support Intel QuickSync in headless Window installation for hardware transcoding. However, it seems it also introduced a bug: server side TrueHD transcoding no longer works regardless if there is video transcoding or not. This is only an issue on my main PMS which has Intel Core i7 6700 CPU. On my secondly test PMS running AMD Ryzen 5 5600U, the TrueHD transcoding works fine on the same server version.
Plex Media Server Logs_2023-07-29_11-42-16.zip (350.4 KB)
I’m having the same issue, my server running an i5-7500. I wonder if it’s a problem only affecting intel cpus (or potentially only the older ones) but hopefully they can fix it soon. Wish we could roll back to an older version of PMS
