Trying to add library's Recently Added to Home screen
Server Version#: 4.108.0
Player Version#: Current FireTV version
I’m wondering how to add a new library’s “Recently Added” to my Home screen. My default Movies and TV Shows libraries appear OK. But am trying to add an Anime library.
In the attached screenshot, I believe this is where I should be able to do it. However, there is no save button for the change I make. If I back out of this screen or even click the up/down arrow, the change reverts (box under Home gets unchecked).
Am I going about this in the right place and way?
TIA
Is the library pinned to the home screen sidebar in whichever app you are using? It needs to be to see the hubs/rows from that library
Do you have “Merge Recently Added items” enabled at the bottom of page you got your screenshot from? if you do it will combine all RA of that library type into one row.
