trying to install agents
I’m trying to learn how to install meta data agents so i thought. So i thought i would try with TVMaze
I downloaded tvmaze-plex-agent-master put it in the plugin folder App Data\Plex Media Server\Plug-ins
closed and reopened media server … thinking it would show up… nothing…
so can anyone tell me what I am doing wrong
Pretty sure you picked the wrong Plug-ins folder. There are two of them. You want the one in your plex data folder, not the one in the program folder.
https://support.plex.tv/hc/en-us/articles/201187656-How-do-I-manually-install-a-channel-
You were correct I was able to add it as an Agent but I was unable to add it as metadata agent for TV shows
I just moved it into the correct folder and it still isn’t appearing in Plex…
