Trying to run xbmc through Pms on win Xp across to ATV3
I have successfully installed each thing and they both work correctly in their own right however when trying to utilize the massive channel repos and addons found in xbmc it just won’t play through the PMS to the ATV. I even installed the Plexbmc repo but still have no luck. Has anyone successfully done this combo? Many thanks in advance.
Aeh... PleXBMC is for the other way around: You run PMS on your server side and use XBMC to play Plex content.
I am not aware of a Plex plugin to access XBMC data.
I have successfully installed each thing and they both work correctly in their own right however when trying to utilize the massive channel repos and addons found in xbmc it just won't play through the PMS to the ATV. I even installed the Plexbmc repo but still have no luck. Has anyone successfully done this combo? Many thanks in advance.
just a sec-is there a way to run xbmc on atv3 using plexconnect ?
how ?
Well that says a lot. Many thanks for your information. I hadn’t thought it was possible but needed to be told by someone with clear knowledge of the Pms product. Aside from the Navi-x addon which loaded fine into plex however doesn’t seem to launch any watchable content for me, does Pms and plex client have other channels or repos or addons other than the content on my Hdd? Thanks again in advance.
There is one great thread about it...
http://forums.plexapp.com/index.php/topic/72875-more-channels-working/
...and it is even pinned!
how ?
I don't think he made it yet... :-D
