Is there a way to turn off Close Captions on Shield AndroidTV when watching LIVETV … they are usually lagging behind and cover a lot of the screen… I would like to have them start turned off and turn on when you want to.
Edit:
Was able to set them to manually selected on the Server … which turns them off on LIVETV but they no longer work when selected when watching recordings …. You are damned if you do and damned if you don’t.
