Turn off "Recent Channel" & "Shows On Now" from Home page
This is less of a technical issue with my tuner or recording but once I set up the tuner and DVR functionality I can not seem to find out where I go to turn off Recent Channels and Shows on Now from my dashboard… if that is even an option. If I have to keep them is there a way to have Live TV & DVR at the top of my side bar but put these to items at the bottom of my dashboard screen?
Customizing the hubs for LiveTV/DVR is not possible at this time.
That sucks, at least on such a basic level of customizing. Please add the ability to turn off Recent Channels & Shows on Now in the near future.
You can ‘Re-Order’ the DVR lower on the Side Bar (and as a result the Home Screen) - so it’s not burning a hole through your forehead every time you look at Home - until you go down the page a bit.
For now.
How do you select what you can see in your HomePage? I wanna add new movies there.
If it is your server, you can pick what is available following this guide Manage Recommendations | Plex Support. You then pin the libraries to your sidebar to make the available hubs appear.
