Server Version#: Version 1.14.1.5488
I am having a issue with episode Files Showing as duplicates when they are not
I have already tried removing them from plex server, delete files,Optimize database, Rename files in standard format, re-upload files.
here is a screen shot of one file that is actually 5 episodes
There is a program called FileBot that will help you a TON if you have a lot of files to rename. I believe the newer versions of it have a Plex preset.
I used Bulk Rename and got all the files done, it was reasonably straight forward. at this time all the TV files are moved over and work. so hopefully i don’t have to do this again.
