Server Version#: 1.21.3.4021
Player Version#: 4.52.1
I have a TV series (Agatha Raisin) which was originally broadcast as 2 hour episodes (90 minutes excluding adverts) and is now being repeated with each episode being in two parts.
These get recorded by the DVR as follows:
Agatha Raisin (2016) - S02E01 - The Wizard of Evesham Part 1.mp4
Agatha Raisin (2016) - S02E02 - The Wizard of Evesham Part 2.mp4
When adding these to the library, these are being identified so that part 2 is identified as the second original full-length episode.
The third option appears to have the episodes split into two, so seems to be what I need but the only episode orderings Plex offers when editing the show are:
Airing order
DVD order
Absolute numbering
Is there any way to allow Plex to use this “2-Part Episodes” ordering?
Plex can currently only deal with Airing, DVD and absolute order.
Plex is currently working on their future tv-show scanner/agent – there’s been discussions about how it’ll handle these different orders and if it’ll also support alternative orders beyond those 3… I suppose the next weeks will show what we’ll be getting to work with
Edit:
As for your actual issue… do I read your post correct that you’re recording the full-length / double-episodes but Plex is labelling them incorrectly as half-episodes?!
Have you considered simply renaming them as s02e01-e02?
No, it’s the other way round. I’m recording the half-length episodes (those are the ones under the “2-Part episodes” ordering in TheTVDB), but Plex is identifying them as the full-length ones.
Does Plex support the “.partn” suffix for episodes like it does with movies?
If I renamed
to
Agatha Raisin (2016) - S02E01 - The Wizard of Evesham.part1.mp4
Agatha Raisin (2016) - S02E01 - The Wizard of Evesham.part2.mp4
would Plex merge them into a single episode and play both files?
Edit: I’ve just tried that and it appears to work, so that seems to be the workaround for now.
