I have found a problem with the guide listings that I am hoping can be easily fixed.
I have set a timer to record Hawaii Five-0 (2010/CBS) that is not being detected. The problem is that the 1968 version of Hawaii Five-0 is being rerun on another channel and Plex is grouping all of the Hawaii Five-0’s under the older 1968 shows. How do I get Plex to separate the two series of Hawaii Five-0 into there correct listings?
I’m also having this problem. It’s a guide data problem. The old show is Hawaii Five-O (with the letter “o”), while the new show is Hawaii Five-0 (with a zero), but Plex’s guide data is listing them all together. I don’t understand how this can even happen today unless someone’s actually manually typing this data. It looks like Tribune lists both at Five-0 (zero), but I don’t know if that would be causing this problem.
