If you have a new way of doing things it has to replace the old. Right now there is a structure for Specials: They go in a Specials folder, a Season 0 folder, or are numbered S00E## most of the specials are already there, so that’s a problem to begin with, but that’s not even what I’m talking about. What I’m talking about is that the Scanner, not the “Agent”, is what determines where things go. You’ll notice that if you edit the Metadata you can’t move an episode to a different season, or a different order, or anything like that. So having the Scanner choose to automatically put anything it finds in a Folder called Featurettes in a separate “Special” folder is a fundamental change.
It’s not just about a “Place” for them.
If you just want a “Place” for them Number them S00E301 & S00E302 then they are in the Specials for the show & you can manually tag them
Or number them S201E01 & have Season 201 as “Behind The Scenes” & Season 304 as “Outtakes” or whatever, in whatever order you want them watched in.
Or if you want them at the end of the season Number them as S05E101
There’s plenty of places, just not a unified one. It’s a non-standard thing that most people won’t use.
This is what I was talking about. Earlier in the discussion when the idea of numbering them, a basic requirement for everything in a TV Show, it was adamantly stated that part of the request is so that they don’t have to be numbered, just put in a folder. The “Structure” used for movies takes anything within a Movie Name (YEAR) folder & anything in the root folder is a different Play Version unless it has a “-DeletedScenes” or whatever at the end. If there are folders it takes anything in a Deleted Scenes folder & puts it in the specials, which is literally just a long scrolling list at the bottom of the movie, with the Deleted Scenes notation underneath it. It uses no numbering & includes everything except for the -Shorts tag & uses those as the name. You have no say in the order they appear in, they are just there. If you have any ( ) it refuses to think it’s a special & tries to add it as a different movie, if you rename a Special Feature you have to Remove, Dance, & re-add the Movie to get it to remove the old one & add the new one, You have no way to edit the title in Plex.
The Series Scanner does not add names. It just doesn’t, It gets the Season, Episode Number, & Show if it doesn’t have clear instructions from the folder structure. That’s it. There ARE 3rd Party Scanners that do, & they have LOTS of problems. They have their uses, but it’s a lot of work to migrate to a different one. Lots of things just aren’t the same, you have to be more cautious with how you name things, Folder’s become more problematic, you can nest series within a Folder Category like you can in Movies (A Feature I like, I have all the Indiana Jones movies in an “Indiana Jones” folder & all the “DCU” movies in a “DC” folder but you can’t do that with Shows in the Plex Series Scanner) But If a folder isn’t labeled “Season 1” it thinks it’s a new show so you’ll have “Season 2 - The Second Plate” as a series. & lots of other issues.
I’m not talking about the Metadata Agent I’m talking about the Series Scanner, the thing that looks in each folder, says “This is a show” or “this is a movie” if it’s a movie the Series Scanner skips it, if it’s a show the Series Scanner looks in it & then looks at each file, it searches for a “Season” marker S04 or Season 4 or the like, if it doesn’t find one on the file it looks at the folder, if it’s in Season 4 folder it determines it belongs in the Season 4 of this show. It then looks for an “Episode” marker E12 or x12 Episode 12 & marks it as “Episode 12 of Season 4”
End Task
That’s it.
The Scanner does no more.
As I mentioned there ARE other scanners that DO look at the title, but they are riddled with other problems, many from the fact that they are NOT as particular in their query.
I’ve actually had this discussion before & Plex will NEVER have it’s scanner do more because lots of users download their files from torrents which apparently have specifics in their naming to name things with Season & Episode numbers, but usually include a lot of other stuff squeezed into the file name like the uploader’s username & some kind of string that makes it easier for them to find the uploader’s other torrents. This is also why embedded Metadata isn’t supported well, because they load the Metadata with spam & links to virus & Phishing pages. So people like me who like to MetaX my rips so they are fully tagged when I imported them into iTunes can’t use them.
So if Plex were to incorporate the name into the extras, aside from making a lot more work for the Series Scanner & making it more likely to have problems with such as broad query, ALL those users who already have stuff according to the old structure would find stuff named weird names, with adds, & potentially with malicious links.
