TV Series - proper recognition for multi-episode files?
anyone having any luck getting Plex to properly display ALL the correct info for a TV Series file that contains multiple episodes?
Sure seems like if ya use the recommended naming structure Plex should be able to properly display the correct info! (#episodes, episode(s) info based on meta data etc)
I get it that ya can’t currently select individual episodes from the file to view and can live with that.
Frustrating end-user viewing/info experience currently! :frowning:
What exactly isn’t working for you?
Example:
TV Shows
  How I Met Your Mother
    Season 07
      How I Met Your Mother - s07e23-e24 - The Magician Code.mkv
Shows as 2 episodes in my library (s7e23 + s7e24), each with their individual metadata.
There’s feature suggestions to improve the handling, ranging from by showing only 1 entry inside Plex that reflects it’s part of a multi-episode file, containing the metadata of all contained episodes, an option to specify a chapter / timecode for when each episode starts within that file to splitting the progress bar across all episodes…
Plex is showing only 4 episodes for these (4) multi-episode files…when there is actual 28..
Dang…wait! I added spaces between the hyphens…that is probably my issue!
Use the format as shown by @tom80H:
Batman The Animated Series - s01e01-e07.ext (ext = mp4/mkv/etc)
not
Batman The Animated Series - s01e01 - s01e07.ext
