TV Show Artwork on Xbox 360
I set up Plex Media Server on my PC to stream to my Xbox 360 and noticed that all of the Movies show the artwork when browsing through the folder but the TV Shows do not. I first went without adding any Local artwork and because nothing was showing up for TV Shows, I added local artwork for them but the images still do not show up on the Xbox 360. I’m trying to figure out if I am doing something wrong. Does anyone know of a reason why the artwork would show up for Movies but not for TV Shows?
My library is set up following the Media Naming Guide. Movies are in one folder “/Movies” and TV Shows each have their own folder and then subfolders for seasons. When I added the local artwork, I placed it in the main folders for each TV Show (not within the individual seasons folders).
Not a showstopper by any means, but just a little annoyance that I would like to fix.
Thanks!
you can check how it should be setup here -> http://wiki.plexapp.com/index.php/Media_Naming_and_Organization_Guide
Does the artwork show in Plex/Web?
