Would it be possible to add a feature where I could specify if the video files are labeled in Aired order or DVD order? From that, I can specify if I want plex to sort them in DVD order or Aired order?
The scanner could change mapping but my scanner is the only one doing so with BABS…
It can show absolute series with seasons and vice versa…
My scanner does support absolute order instead or air date (for Start wars clone wars, as first episode chronologically was something like s02e05) by putting in serie name [tvdb5-xxxxx] with xxxxx being the tvdb id
Some agents does map correctly dvd files like tvdb dvd order agent: https://forums.plex.tv/discussion/21141/dvd-order-agent/p1. That would be the easiest seemingly.
