So the new show Rebel. Simple one word show. Folder structure:
Rebel/Season_1/S01E01-FLEET.mkv
Simple, abiding to standards. Matches:
“The Rebel” from 1959 TheTVdb id = 76434. Does not have secondary name of Rebel.
Should have matched “Rebel” TheTVdb id = 323586
Does not show upon opening Fix Match
Also, when you created the TV Library is it pointed to just /media/plexlibrary/TV ?
Or have you added each letter folder to the library individually as in…
@danjames92 said:
You are using the wrong naming convention. You need to name it correctly.
Google Plex naming convention and click the top link.
Also update to the latest server release you can as there were various matching issues on the 1.4.x releases.
Naming convention of the episode file? Having the series name in the filename in a folder with the series name is redundant. And if that were the issue it wouldn’t even match to the incorrect Rebel.
And I’m on v1.5.x
The files and folders needs to be named like below.
/TV Shows
/Grey's Anatomy
/Season 01
Grey's Anatomy - s01e01.avi
Grey's Anatomy - s01e02 - The First Cut is the Deepest.avi
Grey's Anatomy - s01e03.mp4
/Season 02
Grey's Anatomy - s02e01.avi
Grey's Anatomy - s02e02.mkv
Grey's Anatomy - s02e03.m4v
Also sometimes adding the date the show was created helps IE. Sirens for me would always give the 1990’s version of the show and not the 2014 version.
