tv show naming options
I have been using the renamer for a long time but with the last windows update is does not work anymore . what else is everyone using or is there a fix?
I use FileBot with this string {n.replaceTrailingBrackets()} - {s00e00.lower()} - {t.replaceAll(/[!?.]+$/).replaceAll(/[`´‘’ʻ]/, “’”).lowerTrail().replacePart(’, Part $1’)} or this more simple one {n.replaceTrailingBrackets()} - {s00e00.lower()} - {t}
There is also a Plex preset format that is more complete and even creates/uses the correct folder structure but I create my own structure that follows the Plex convention so I find using the simpler format string better for me.
There is a small one time fee for FileBot but it is well worth it. There is also a way to get an older version for free but I do not really know how and I think software like FileBot should be supported.
You did not say what OS you are using but I think FileBot is only for Windows but you can visit there website to fine out for sure.
i have file bot but i never like the way it named with 1x10 where renamer used S1E3 ,.you stated “There is also a Plex preset format that is more complete and even creates/uses the correct folder structure but I create my own structure that follows the Plex convention so I find using the simpler format string better for me” i have never saw that option i have the older version. maybe its not in there? I main use is plex! I am running window 10
