TV Show not importing to library
Server Version#: 1.20.2.3402
Ubuntu
Hi there. I have 99% of my movie / tv library imported correctly. I have like 10 shows that won’t import to the library. The below video I went in with AtomicParsley and I saw that the file Crane.m4v did not have any metadata so I added in the basic series name, show name, season #, and episode #. Now it will show up in the logs when I run a manual scan but, still does not show up in the library? Any advice?
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - Updating part with ID=14583 [/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v]
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - Part hashes for media item 14579 have changed.
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - [ID 14583] Media part analysis: /media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v
Feb 06, 2021 10:30:03.637 [0x7f7b8ad23700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - [MI] Opening input file: "/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v"
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - [FFMPEG] - Opening '/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v' for reading
Feb 06, 2021 10:30:03.637 [0x7f7b837fe700] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Feb 06, 2021 10:30:03.638 [0x7f7b837fe700] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Feb 06, 2021 10:30:03.638 [0x7f7b837fe700] DEBUG - [FFMPEG] - ISO: File Type Major Brand: mp42
Feb 06, 2021 10:30:03.638 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.641 [0x7f7b837fe700] DEBUG - [FFMPEG] - Processing st: 0, edit list 0 - media time: 6006, duration: 129092964
Feb 06, 2021 10:30:03.642 [0x7f7b837fe700] DEBUG - [FFMPEG] - Offset DTS by 6006 to make first pts zero.
Feb 06, 2021 10:30:03.642 [0x7f7b837fe700] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Feb 06, 2021 10:30:03.642 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.644 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.645 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.645 [0x7f7b837fe700] DEBUG - [FFMPEG] - Processing st: 3, edit list 0 - media time: 6006, duration: 129092964
Feb 06, 2021 10:30:03.645 [0x7f7b837fe700] DEBUG - [FFMPEG] - drop a frame at curr_cts: 0 @ 0
Feb 06, 2021 10:30:03.645 [0x7f7b837fe700] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 310739851 bytes read:1231142 seeks:8 nb_streams:4
Feb 06, 2021 10:30:03.646 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.646 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.647 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Feb 06, 2021 10:30:03.647 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Feb 06, 2021 10:30:03.647 [0x7f7b837fe700] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Feb 06, 2021 10:30:03.647 [0x7f7b837fe700] DEBUG - [FFMPEG] - no picture
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [FFMPEG] - All info found
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 1071316 bytes read:1263910 seeks:9 frames:12
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [MI] Opening "/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v" for MP4 atom parsing
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 28 at offset 0
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Skipping free atom of size 132 at offset 28
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found moov atom of size 1065371 at offset 160
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found trak atom of size 644038 at offset 300
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found trak atom of size 346234 at offset 644338
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found trak atom of size 72148 at offset 990572
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found trak atom of size 588 at offset 1062720
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found mdia atom of size 643882 at offset 400
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found minf atom of size 643809 at offset 473
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found stbl atom of size 643745 at offset 537
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found co64 atom of size 85992 at offset 172762
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [MI] File has co64 atom with size 85992 at offset 172762
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found tref atom of size 20 at offset 644282
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - Mp4AtomParser: Found chap atom of size 12 at offset 644290
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [MI] Determined stream id 4 has chapters, not subtitles
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [MI] * 7ca77f731b22a62243cff373bed131cdf86b4069 [mp4 h264/aac] Duration: 1434366ms, 720x480 (1.772840)
29.970fps, bitrate=1733kbps, audio channels=2, optimizedForStreaming=1 ("/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v")
Feb 06, 2021 10:30:03.648 [0x7f7b837fe700] DEBUG - [MI] Importing 6 media chapters.
Feb 06, 2021 10:30:03.649 [0x7f7b837fe700] DEBUG - [MI] Closing input file: "/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v"
Feb 06, 2021 10:30:03.649 [0x7f7b837fe700] DEBUG - Streams didn't change in analysis, not saving.
Feb 06, 2021 10:30:03.649 [0x7f7b837fe700] DEBUG - Updating media item 14579, size=310739959, metadata_item_id=2997
Feb 06, 2021 10:30:03.649 [0x7f7b837fe700] DEBUG - Updating part with ID=14583 [/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v]
Feb 06, 2021 10:30:03.649 [0x7f7b8ad23700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=2&metadat
aItemID=2997&metadataType=4&state=-1&mediaState=analyzing
Feb 06, 2021 10:30:03.649 [0x7f7b837fe700] DEBUG - [MI] Opening input file: "/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v"
Feb 06, 2021 10:30:03.650 [0x7f7b837fe700] DEBUG - [FFMPEG] - Opening '/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v' for reading
Feb 06, 2021 10:30:03.650 [0x7f7b837fe700] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Feb 06, 2021 10:30:03.650 [0x7f7b837fe700] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Feb 06, 2021 10:30:03.650 [0x7f7b837fe700] DEBUG - [FFMPEG] - ISO: File Type Major Brand: mp42
Feb 06, 2021 10:30:03.650 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.650 [0x7f7b8ad23700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=2&
metadataItemID=2997&metadataType=4&state=-1&mediaState=analyzing
Feb 06, 2021 10:30:03.650 [0x7f7b8ad23700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=2&metadat
aItemID=2997&metadataType=4&state=-1&mediaState=thumbnailing
metadataItemID=2997&metadataType=4&state=-1&mediaState=thumbnailing
Feb 06, 2021 10:30:03.652 [0x7f7b837fe700] DEBUG - [FFMPEG] - Processing st: 0, edit list 0 - media time: 6006, duration: 129092964
Feb 06, 2021 10:30:03.654 [0x7f7b837fe700] DEBUG - [FFMPEG] - Offset DTS by 6006 to make first pts zero.
Feb 06, 2021 10:30:03.654 [0x7f7b837fe700] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Feb 06, 2021 10:30:03.654 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.656 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - Processing st: 3, edit list 0 - media time: 6006, duration: 129092964
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - drop a frame at curr_cts: 0 @ 0
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 310739851 bytes read:1231142 seeks:8 nb_streams:4
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Feb 06, 2021 10:30:03.657 [0x7f7b837fe700] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - no picture
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - All info found
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 1071316 bytes read:1263910 seeks:9 frames:12
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/7/ca77f
731b22a62243cff373bed131cdf86b4069.bundle/Contents/Thumbnails/thumb1.jpg (50.0%, 720x512).
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Feb 06, 2021 10:30:03.658 [0x7f7b837fe700] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Feb 06, 2021 10:30:03.663 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Feb 06, 2021 10:30:03.663 [0x7f7b837fe700] DEBUG - [FFMPEG] - no picture
Feb 06, 2021 10:30:03.665 [0x7f7b837fe700] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Feb 06, 2021 10:30:03.681 [0x7f7b837fe700] DEBUG - Loaded memory image of size 850x480.
Feb 06, 2021 10:30:03.696 [0x7f7b837fe700] DEBUG - [MI] Closing input file: "/media/ssd-internal/TV_Shows/Yoga_Videos/Crane.m4v"
Feb 06, 2021 10:30:03.696 [0x7f7b837fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Feb 06, 2021 10:30:03.696 [0x7f7b837fe700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Feb 06, 2021 10:30:03.697 [0x7f7b837fe700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Mod-Edit: added some code-tag around that log to make it easier to read
Let’s start with naming them in a way that Plex will recognize.
Plex will ignore files that don’t have a pattern identifying them as tv-show files.
Just because your file naming and file structure has worked in the past, does not mean it will continue to work.
It will work, till it doesn’t.
