TV show ratings are excessively high
Server Version#: 1.26.2.5797
So for the last 3 months or so, newly added tv shows have ratings scores in the ten and some times hundreds of thousands.
Just added the show “The Lost Room” and it shows a score of 412950%…
Im using the TVDB agent.
Anyone know of this?
IIRC I’ve been reading this is an issue with old TheTVDb API which is no longer officially supported.
The beta of PMS 1.27.0 is addressing this and will no longer attempt to download ratings from TheTVDb.
Ok cool thx for the reply!
So is “Plex Tv Series” the replacement?
I’m a bit scared to change the agent if my 200+ shows will get screwed over
Yes, “Plex TV Series” is the current-generation Plex agent for tv-shows.
There should be an option under Activities to upgrade your legacy libraries.
