TV Shows Messed up
I’m a long time user of Plex. Recently my TV shows are messed up. I’ve searched and tried all the recommendations but nothing works. I may get some shows to show up correctly, but then it just goes back to being messed up and only shows part of my episodes in the correct TV show and puts the rest into Aqua Teen Hunger Force (never heard of it and most certainly have never ripped any of the shows!)
I’m naming the files correctly, as I always have.
Ended up having to use Handbrake to make all my files into .m4v so we could watch game of thrones via Apple…
Please show the file names you are using for one of the affected shows.
Please do include the full folder path as well.
Finally, edit your tv show library and tell which folder patrh is appearing under the ‘Add Folders’ tab.
Game_of_Thrones (2010) (it was originally just Game of Thrones but I added the 2010 as one of the so called fixes.
Season 01 (ALL of my tv shows whether 1 season or 500 seasons are labeled this way with the preceding 0)
Game of Thrones - s01e01 - Winter is Coming.mkv
/Volumes/TV/TV Shows
Did you check the meta-data in the file to make sure it matched the file name?
Is your server set up for Local Media Assets as you default for Agents?
Folder and path names are ok.
Now what about the second part of my question?
