TV Shows not appearing
Hi Tom.
Sorry, I think that was the point I was making but not very clearly – basically, I can’t see the options outlined in that previous solution when I try to access it via my Nvidia Shield so I can’t fix it that way, but if there’s a way I could get it working on my Mac (removing the Nvidia from the equation for now) then I assume it would then work on the Nvidia?
Thanks for your ongoing help!
I am having the same problem, however I am able to see the TV shows on Web Apps but not on the Nvidia Shield.
in which case it’s not the same issue…
(a) server not able to read files from a certain folder
(b) a client not seeing a certain library
are you ok to move your question in a separate post in order not to create further confusion?
Hi Tom.
Hope you’re well.
Just wondered if my previous message had been any help in providing clues for what’s going on?
Best,
Nick.
Sorry… I’ve run out of ideas
Is there any other info I can share, or anyone else that can pick this issue up? It seems odd that I can see Movies and Music but not TV, and I’d love to be able to resolve this if possible.
