I having problems with TV Shows. The shows I have are coming out as different shows after scanning the library… I have named the shows correctly and us filebot but still keep getting problems. What else can I try to do?
Thanks.
David
Thanks.
David
You cannot use the top level folder as the ROOT within plex.
ROOT
for a particular library… so it’s trying to match 16 shows (Dragon Ball Z (1989) not included because it's the root
) named Season 01, Season 02, Season 03, Season 04, ~ Season 16. Sometimes it will find and match to the correct series but often times it will not and match stuff randomly to whatever it thinks./volume1/Movies/TV Shows/
one time because that is your ROOT of all your shows.
Additionally, move the “TV Shows” folder out of your “Movies” folder.
Strictly separate movies and TV shows.
Thank you all. It is working now, and I’m not getting all the problems I was having before.
