TV Shows not showing Banners, Poster, etc
Server Version#: 1.20.5.3600-47c0d9038
Player Version#: 1.23.0.1435-e10e14cf
Hello, I’m having trouble displaying Banners, Poster and background. All the rest of the metadata works fine (Synopsis, actors, etc…) !
It works absolutely fine on Movies.
Here is a picture :
https://i.gyazo.com/e79cdd43ff7d194ae2bca4c06d9e2140.png
I searched about everything I could, but no luck.
Thank you for your help !
A fresh install this morning did not fix the problem by the way (New VM, new everything), movies show just fine, still the same problem with TV Shows regardless of Agent.
Do you use some kind of ad blocker or javascript blocker in your browser? Please disable it for plex.
Hey @drmagoo, thank you so much for your answer. No adblocker or else on my side. But the problem seems to have solved itself a few minutes ago.
I have no idea why, but thank you anyways !
