TV shows not showing up in discover
Hello,
Love the new feature. In the ‘Trending on your services’ section when you have a movie in your personal library it shows a location from which to view the content in your library as well as the online services.
It doesn’t seem to do the saem for TV shows however. For example ‘The Big Bang Theory’ only shows online sources when it also exisits in the the library.
I’m sure I have the correct agent selected for the TV Show librabry also. Can you confirm what it should be.
Thanks, keep up the great work.
This will be working fine for TV shows as well.
Best review if your library is already using the current-generation Plex TV Series agent (and metadata has been refreshed so the agent is actually applied to all items).
Thank you, a rescan fixed the problem.
