TV Shows Optimize
In looking at ‘Optimize’ from my TV Shows library Limit to 5 times is checked, Unwatched only is not checked, ‘Optimized for Mobile’ is selected, does this mean some of my TV shows are being optimized?
Optimized Versions under Settings | Manage has nothing listed.
Full screenshot please!
This is just the dialog box to start the optimization process.
If you don’t click on the orange ‘Optimize’ button, nothing gets optimized.
Thanks. I can’t find it now but I did delete an automatic scripts that I setup to do this for new items.
What kind of script?
If you had any scripts, then these were made by a user.
What are you after? What do you want to do?
There is a lot you can do even without external scripts, just by using the regular filter system.
You can set up optimization jobs just like ‘smart’ playlists in Plex.
(Same goes for Sync jobs, btw.)
Hello Otto, I really appreciate your input. I think my problem was when telling Plex to optimize 5 items per the above screen and then seeing them all queued up under the ‘MANAGE | Optimized Versions’ screen I thought this we a waste of time and wanted to cancel the option.
