so - I've been keeping my PlexConnect updated (pretty much doing a pull from git once a day, at least) and it's been working just dandy from the minute I installed it way back up until this weekend. Do not know if it's a issue I have with a recent commit or if it's something else.
But, this is my issue:
My storage setup is set up like the following:
Drive 1
- TV Shows
Drive 2
- Movies
- Others (a folder with no scrobbler just serving temp-content)
What happens is that TV Shows and files from Other play just fine, but as soon as I try to enter the movie grid on Movies - I get a "Trailers is unavailable"-error message. I see thumbnails from Movies in the main menu, but as soon as I try to enter "All movies" (or any of the other filters) I get the error.
I have an aTV 2 running the latest iOS (6.0.2)
PMS version is 0.9.9.2
I've deleted and re-created certs, deleted and recreated settings.cfg
Can you create a new Movie section in PMS with just a coupe of movies in it and try to access that. Looking at you log, it seem your movie section is trying to access the Directory template and I’m not sure why, could you also update to the latest commit from today.
Trying to always stay on the latest commit, will do a new pull and try that - if that doesn't work, I'll create a new section. Give me a few and I'll report back!
Creating a new section seems to be working. Do you want me to just create a new one or do you need me to further test something?
First thing to try is shut down PMS and restart it to see if that fixes the problem, failing that all I can suggest is delete the Movie library section and recreate it :(
