TV-Shows Problem?!
Hey together, I have this problem. Plex packed all Tv-show to a one show. See at the Picture:
At which folder is the tv shows library pointing?
It must be W:\SERIEN\0-9 and not just W:\SERIEN
It is only in W:\SERIEN
Yes, you can’t do that. Your ‘index’ folders are confusing the scanner. You need to add each ‘index folder’ individually to the library.
For clarity: I don’t say you need to create separate libraries for each index letter. You just need to add each index letter folder on disk to the same library separately.
See [feature request] Add support for alphabetically directory support for TV Shows, like Movies for an illustration.
