Server Version#:
Hi, why do some series show correctly when using the SE01EP01 and other i have to change to the 1X01 format?
NOTE: i fixed this by using tvdb. still, why does it do this when using the plex scanner?
Server Version#:
Your naming format is incorrect.
Follow this article https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
But the format should be s##e##. The linked article will show examples of the recommended naming convention.
-Shark2k
thank you i’ll try that.
Yeah S##EP## is incorrect, try S##E##
