TVButler 100TCV is not working with Synology
Server Version#: PlexMediaServer-1.20.2.3370-b1b651549-armv7hf_neon.spk
Tuner Make/Model: DVBLogic TVButler 100TC
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hello together,
I looked the forum for this issue and found some threads but none with a solution.
I would like to use the TVButler 100TC as Tuner for Plex on my Synology DS2015xs, but it wont work at all.
I connected the stick to the Synology, checked DSM → Settings → Info if the stick is detected by the Synology it self (it is present).
Then I open Plex, enter the settings menu, choose LiveTV and click on setup LiveTV.Then the Plex is looking for the tuner and does not find anything.
My Synology is running DSM 6.2.3-25624 Update 2.
I dont have the DVBLink Server/TVMosaic or the Video Station running.
I found a post regarding some permissions need to be changed within the DSM filesystem but I could not find the file.
Does anyone have an idea of what is going wrong and how to fix it?
Best Regards
Does no-one have an idea?
