Live TV & DVR - Synology DS216j and TVButler
Server Version#: 1.24.3.5033-6000
Tuner Make/Model: TVButler
NAS: Synology DS216J
NAS Operation System: DSM 6.2.4 -25556 Update 2
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hi I am trying to get the live TV with a TVButler Stick in Plex to work. I saw this was a problem in some post earlier. But I could not see if and how these problems have been solved.
As mentioned I have a Synology DS216j. The TVMosaic Software is running and working. Over cable it has found about 125 tv channels.
As the TVMosaic will not work under Synology DSM 7.0, I am looking for alternatives and found Plex Media Server. But I can only use it, when Live TV by cable with TVButler Stick will be possible.
In Plex it finds the TVButler Stick, It shows also a list of local DVB-C Providers (it’s about the same list like in the TVMosaic Software), but after choosing a provider, it beginns to search and after a little while it returned with the message ‘no channels found’. It doesn’t matter which provider I choose, it is always the same.
In TVMosaic I could enter the information about the frequency, symbol-rate, network id and that stuff manually (as mentioned form the DVB-C Provider), and it found then all the free tv channels. In plex this seems not possible, at least I have not found an option like this.
I would like to buy a plex-pass but as long as Live TV doesn’t work for me, it would be lost mony for me.
Enclosed is the ‘Plex Tuner Service.log’ File. I see, there are some entries with an error.
Oct 10, 2021 18:17:26.566 [0x74d5dd78] WARN - [E] web_service_t::get_device_status. get_device_info returned error for device dvb#tvbutler#0#3:1
Oct 10, 2021 18:17:26.788 [0x7484ed78] WARN - [E] web_service_t::get_device_status. get_device_info returned error for device dvb#v4l#0#/sys/devices/soc.0/internal-regs.1/f10f0000.usb3/usb1/1-1
But could not figure out what does these errors mean, because the stick is working proberl with the TVMosaic software on the Synology.
Plex Tuner Service.zip (13.8 KB)
Any ideas what i could do to get the channels?
Bruno
0 replies and 28 views. Sadly Plex doesn’t give a shxt. Sorry to say that, because there is a ton of threads that are similar that they don’t respond to. And those of us that are paying customers say, WTF? Crickets… Could be a great platform, but they have abandoned that notion.
