Server Version#: PlexMediaServer-1.22.0.4163-d8c4875dd-x86_64.spk
Tuner Make/Model: TVButler 100TC by DVBLogic
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hello,
I have a TVButler USB Stick (from DVBlogic) and trying to use it on my PMS (1.22) on my Synology DS1817+ (DSM running 6.2)). I’m in France, using Cable and or Antenna (working fine on regular TV) and the TVStick is working (I did connected to a PC running Mosaic workign like a charm)
I uninstalled all other DVR software from my DSM, including the DVBlink, VideoServer and MediaCenter
under PMS, the USB device is properly detected, but whatever signal I’m trying to scan, Plex is unable to find any channel.
I’ve tried to dig into the USB setup files but can’t really say it it is ever related.
from tailing Plex Tuner Service log file from Synology during a scan, i got some warn messages but no errors, sample below:
Mar 10, 2021 00:01:08.312 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 770000,8,
Mar 10, 2021 00:01:14.691 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 769833,8,
Mar 10, 2021 00:01:21.010 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 770167,8,
Mar 10, 2021 00:01:27.380 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 778000,8,
Mar 10, 2021 00:01:33.829 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 777833,8,
Mar 10, 2021 00:01:40.224 [0x7fe193a23700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 778167,8,
on the Plex Media Server log file I have nothing interesting (plenty of DEBUG messages for get/post request on the server…)
is there anything I can do / advice from a similar configuration ?
Thx a lot in advance
Thomas
