Hello,
I noticed that with version 1.0.1 and 1.0.2 of PMS the TVDB agent is not working well with TV Shows, in particular it cannot download posters. Metadata of series and episodes are ok, also the music theme is good, but there are no posters at all.
Downgrading to 1.0.0 fixes the problem (I supposed is the new TVDB API v.2 that are not working well. this feature is introduced with 1.0.1).
I traced the problem into the log:
2016-07-21 21:15:03,791 (7f4811ffb700) : CRITICAL (agentkit:1067) - Exception in the update function of agent named 'TheTVDB', called with guid 'com.plexapp.agents.thetvdb://289590?lang=it' (most recent call last):
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py", line 1065, in _update
agent.update(obj, media, lang, **kwargs)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/TheTVDB.bundle/Contents/Code/__init__.py", line 1084, in update
self.processExtras(xml, metadata.seasons[season_num], lang, ivaNormTitle)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 96, in ObjectFromString
check_size(string, max_size)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 22, in check_size
if len(data) > max_size:
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 254, in __len__
self.load()
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 181, in load
f = self._opener.open(req, timeout=self._timeout)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 444, in open
response = meth(req, response)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 557, in http_response
'http', request, response, code, msg, hdrs)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 482, in error
return self._call_chain(*args)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 416, in _call_chain
result = func(*args)
File "/opt/plexmediaserver/Resources/Plug-ins-7caf41d/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 565, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
