TVDB manual match not working
Hi everyone,
First , I would like to say that I have seen the user manual and also some post on the forum.
I have a library dedicated to TV documentary. Most are identified but there are some that are not.
I have tried to manually match them by searching the name and also with the TVDB ID. But even that method doesn’t work.
Can you help me to understand why ?
I have different examples :
I checked the library configuration and here are the main informations :
  • Scanner : Plex Series Scanner
  • Agent : The TVDB
These are both standalone documentaries and are considered movies (the IDs you provided are movie IDs). As such, you’ll have to place them in movie-type libraries on your server. You’ll likely find this is the case for most (all?) standalone documentaries, that is, those that are not part of a series.
You are right. Thx a lot.
No problem, hope it works for you.
