Plex TV Scanner nok matching documentaries
Server Version#: 1.25.2.5319
So, my wife managed to find a couple of documentaries that I can’t match at all using the Plex TV Series Agent/Scanner.
It’s the following series:
https://thetvdb.com/movies/where-to-invade-next
https://thetvdb.com/movies/pick-of-the-litter
https://thetvdb.com/movies/tickled
Trying to match by ID doesn’t return any hits either (For example searching for tvdb-9756 results in “No matches found.”)
These are all movies, they won’t match in a TV series library. You need to match them in a Movies library.
Allright! Thanks for the quick reply. :slight_smile:
Kinda annoying as I want to have all documentaries in the same library regardless of it being one episode/movie or a multi episode series. I guess these will have to stay unmatched then.
docos you DEFINITELY need two libraries for movies and tv., it’d almost be like being annoyed that you’ve created a superhero library but some are tv and some are movies - the content doesn’t matter to plex at all.
