TVDB not finding show
There are 2 different shows (the haunting of hill house 2018 and the haunting of bly manor 2020) but when I try to match them, they only match under one series (The Haunting 2018) - How do I match each one to the separate series?
The Haunting of Hill House https://www.imdb.com/title/tt6763664/?ref_=nv_sr_srsg_0
The Haunting of Bly Manor https://www.imdb.com/title/tt10970552/?ref_=nv_sr_srsg_0
Plex Match for both: The Haunting https://thetvdb.com/series/the-haunting
Thank you for the help!
Look at the episode names in TheTVDB and IMDB.
The Haunting of Hill House is Season 01 of The Haunting in TheTVDB.
The Haunting of Bly Manor is Season 02 of The Haunting in TheTVDB.
Try:
/TV Shows
   /The Haunting
      /Season 01  <-- This is The Haunting of Hill House
         /The Haunting - s01e01 - Steven Sees a Ghost.ext
      /Season 02  <-- This is The Haunting of Bly Manor
         /The Haunting - s02e01 - The Great Good Place.ext
Edit: Using above organization:
Screenshot (278)
Thank you so much! that is what it was, I added them to the same folder before and named one season 1 and one season 2 but I now see I had to change all the file names (since they were both S1 they merged into one). With your reply I realized I had to rename S02 for bly manor, thanks again!
