I know this was an issue recently but PMS still isn’t able to match any media against TVDB - com.plexapp.agents.thetvdb.log shows:
2016-09-24 16:57:26,705 (7fe23e7fc700) : ERROR (networking:219) - Error opening URL 'https://tvdb2.plex.tv/login'
2016-09-24 16:57:26,706 (7fe23e7fc700) : INFO (__init__:136) - JWT Error: (HTTP Error 403: Forbidden) - ```
status.plex.tv doesn't show any current problems, and the issue remains after removing/reinstalling the PMS 1.1.4 package (on Ubuntu 16.04.1 64-bit). Is this is PMS issue or tvdb2.plex.tv issue?
The problem could not be reproduced. May be a caching issue to do with a specific route
Could you get the output from nslookup tvdb2.plex.tv
Please also send me you public IP address by Private Message
Thanks for the update - I checked out the DNS resolution and this one is user error. During the previous TVDB service issue I played around with directing tvdb2.plex.tv directly to thetvdb.com’s IP address (104.23.107.176) via /etc/hosts to see if it would work as a temporary patch and promptly forgot about it.
Cleaned that out and all is well - thanks for the pointer and apologies for impugning the honor of the tvdb proxy servers!
Thanks,
Nikhil
Side note - it was interesting to see that the proxy servers would resolve correctly even with the wrong IP on tvdb2.plex.tv, but forbid the connection (as they should):
$ nslookup tvdb2.plex.tv
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
tvdb2.plex.tv canonical name = proxy.plex.tv.
proxy.plex.tv canonical name = proxy.plex.bz.
proxy.plex.bz canonical name = proxy00.pop.ord.plex.bz.
Address: 23.96.179.174
