Two albums created from one
Server Version#: 1.15.3.876-ad6e39743
Player Version#: Version 3.83.2
Everytime I use Win media player to rip a CD Pllex makes 2 albums but one only has the first song in it. 2 thru whatever are in another…
Are you ripping directly into a folder which is being “watched” by Plex?
Don’t. Always rip all tracks, rename them, check metadata in a separate folder, outside of a Plex library. Only after, that move the complete album folder into a Plex library.
In order for Plex to recognise a bunch of tracks as belonging to the same album, you need to:
  • put all tracks into the same folder
  • give all tracks identical content in the ‘AlbumArtist’ and ‘AlbumTitle’ metatags. If ‘track number’ and ‘Disc number’ meta tags are present, they should be present in all files of the album.
  • even if you use correct meta tags, do also use file names and a folder structure according to this guide: https://support.plex.tv/articles/200265296-adding-music-media-from-folders/
Here are some more tips regarding music
multi-disc albums
handling singles and EP’s
https://forums.plex.tv/t/best-way-to-add-album-singles-ep-to-a-premium-music-library/128108/8
possible ‘side car’ files for music
soundtracks and ‘various artists’
I am ripping into Win media player and Plex imports them. This started after a Plex update. …Do I make a change in Media player or plex?
You let WMP rip into a folder, on your hard drive.
If you have pointed Plex to that very same folder, then weird things can happen, as you have seen.
If you don’t want to separate the folders of WMP and Plex, then do at least disable the automatic library update of Plex. To prevent Plex from scanning a half-ripped album.
(Settings - Server - Library)
Thank you, that I can do. This did not happen previously as I ripped over 100 cd’s over a year ago. Just happening.
