Two Different Plex Pass Accounts
Evening All,
After an issue with double-NAT I am finally up and running, however in order to test it out at the in-law’s house (which could take weeks…) I instead wanted to see if another Plex Pass account holder could see/play my server and it’s contents in his own Plex app. Is it possible for two Plex Pass accounts to be logged in at the same time, or does it require that in order to view his or mine that we have to logout/login to one another’s accounts and vice-versa?
You just need to share your content with another Plex Pass user or normal user for that matter. Then they can stream your content, if its viewable.
however, all you really need to do it test if from a portable player like a phone (turn off wifi) and it will play from outside the network
