Two Homes - Two Servers?
I have a main home and a vacation home. I think I would like to have a Plex Server installed at both places, just in case one of the Windows PCs is shut down for some reason… that way I can access my music from either place with Sonos. I am assuming that this is possible but not sure how to set it up. I guess if I wanted to go to Plex Pass, this would not be an issue… correct? Sorry this is such a new user question but I think Plex might be what I have been looking for because every time I set up a DLNA external hard drive cloud… at some point it goes bad and then I have to start all over again. Thx in advance!
  1. You can have more than one server connected to your plex account.
  2. Plex pass is not necessary for that
  3. there are no/zero/zilch mechanisms for synchronising media files and/or metadata (unwatched/watched) between servers
If your vacation home has an internet connection, there are no hindrances preventing you from setting up a second plex server.
Thanks so much. I figured that this minimal approach would work… and I understand that there will be no syncing between the two music libraries (from the two Plex Servers)… to do the cloud syncing, as I understand it, would be to use a “cloud” such as Amazon Drive… but in reading the info on Plex Cloud Syncing, it wont utilize any music flies I place on the Amazon Drive manually… that it is done by the Plex Server and Plex Pass and it only syncs what I tell the Plex Server to place on the Amazon Drive…
I was hoping that I could have a Cloud drive (such as Amazon) where all my music flies would reside and Plex would utilize it… but that is NOT the case, if I understand correctly.
Thx again!
This will be possible with the Plex Cloud Server which is currently just starting preliminary tests.
https://www.plex.tv/blog/book-plex-volume-3-plex-cloud/
